500+ hp motor plus 200shot what kind of fuel set up do i need
Old 05-22-2009, 08:50 PM
aug181983's Avatar
Default 500+ hp motor plus 200shot what kind of fuel set up do i need
ive got a 12.8-1 383 pushing 500+hp and i want to put a 200shot on it. I have all stock fuel system in the car otherthan the 255pump. I was told i can run a Stand Alone System but my issue i have right now is Money. so if i can figure out away to keep this entire fuel system under $600 that would be ****.
another thing would be i just install a 2nd wahlbro pump if thats the case i only see right ups on 98+ cars i have a 97 t.a so how can i do that. and will i still need the bucket in my gas tank for the pump cuz i was told i need the bucket. if this does work just by using the twin pump how much power is it capable of
Old 05-22-2009, 08:52 PM
RamAir95TA's Avatar
You should know by now that a 700HP motor requires alot more than a $600 fuel system.
Old 05-22-2009, 08:54 PM
vanilla89's Avatar
i think a 255pump and a racetronix wiring kit should be fine..
Old 05-22-2009, 08:57 PM
aug181983's Avatar
255 pump-600hp and thats pushing it i was told
Fuel Pump Controller OR Fuel Pump Booster ?????
I was thinking maybe one of these but will i have to change my entire fuel lines on the car also?
Old 05-22-2009, 09:07 PM
LS1TECH Sponsor
Lonnies Performance's Avatar
You are above what a single pump can provide.
I offer a dual pump kit that will support over 1000rwhp.
Give me a call & I can set you up with everything you need for a complete fuel system.
Old 05-22-2009, 09:09 PM
aug181983's Avatar
well i dont have 600+ dollars bro and i know someone out there on TECH got something up there sleeve. LT1 guys are crazy and figure out ways to make the bitch FLY so im sure someone gotta know something on a low budget idea.
i knew i was right SOMEONE out there always has something up there sleeve
thanks alot fellas my wife will be very happy to know her car should be running shortly
Old 05-22-2009, 09:10 PM
RamAir95TA's Avatar
Then you're gonna have a sub-par fuel system that won't be able to keep up. You gotta pay to play.
Old 05-22-2009, 09:23 PM
aug181983's Avatar
dont you think a 255pump and a booster will do the job? Or will i have to replace the lines + booster ?
thanks
Old 05-22-2009, 10:40 PM
Self-Admitted Scammer
ls2pontiac's Avatar
What about a racetronix in-tank and an inline high pressure fuel pump as well?
Old 05-22-2009, 11:30 PM
robsquikz28's Avatar
i have seen the inline pump with the 255 pump support 700 horsepowe before but i think the best way would be either a stand alone system or doin the dual pump in the tanks which can be done quite easily and will be very beneficial to the motor its not hard to make or install and for standalone you can make one for less than 500 bucks
Old 05-22-2009, 11:58 PM
SoxXpupPeT's Avatar
and pay you will when you detonate and blow a hole in your block
Old 05-23-2009, 06:43 AM
LS1 SPEED's Avatar
twin intanks and a hot wire kit will get the job done
This will support over 1000HP as Lonnie mentioned.
Old 05-23-2009, 06:48 AM
z28rob18's Avatar
or you can piece together you own stand alone. a few ppl have done it and it cost them about 400 to do it. fits your budget and ur needs. larry hows that twin in tank set up?
Old 05-23-2009, 07:10 AM
LS1 SPEED's Avatar
The twin intaks we do is rather simple.
SS Y
2 pumps on the stock hanger ( tight )
hotwire kit which has a lead for the second pump
This is then ran through the stock feed and we have been over 900 rwhp in turbo cars w/ TH400's.
Old 05-23-2009, 10:32 AM
thats it very, if you dont want to use a y fitting you can use a t fitting then you can wire up and turn on when you want it to work, very cool and inexpensive
Old 05-23-2009, 11:15 AM
Stroked96Bowtie's Avatar
Run a seperate fuel system for the NOS, use the single intank to power the motor and get an HSW cell with a pump built into it to run your kit. You can wire it to come on when you put power to the noids, flip one switch to power your pump and NOS.
Old 05-23-2009, 11:52 AM
z28rob18's Avatar
SS Y
alright so that sounds simple. i have the hotwire kit on the way and a 255 from you. could i do this set up with the 255 and stock pump to support the extra hp? i should be right at the limit of the 255 on n2o so if i wired it up lik this with the 255 and stocker it should support the car with n2o correct? or do i need two 255s because the stock wont kep up with the 255?
Old 05-23-2009, 12:31 PM
those will both work the only thing is that the 255 pumps will support near 1000rwhp as for the stock pump and the 255 it might be near 850 but dont quote me on that number
Old 05-23-2009, 12:38 PM
z28rob18's Avatar
if the stocker and 255 supported 750 itd be fine. i might be making 700 on a 200 shot. where can i get the Y from anywhere?
Old 05-24-2009, 12:21 AM
Wicked94Z's Avatar
make a standalone out of your windshield washer tank for <200 bucks
Quick Reply: 500+ hp motor plus 200shot what kind of fuel set up do i need
