major tune up
Air cleaner: $10.00
6 Spark plugs: $12.00
Fuel filter: $12.00
Can of Sea Foam: $8.00 (to run through a 1/2 tank of gas to clean your fuel injectors....THEN you change the fuel filter)
1 hour of your time.
Thats it.
You could also do a top end cleaning of your engine, that will require one more can of Sea Foam.
***Assuming nothing is broken or worn out***
