Using a A4 harness on a 6 speed
Im using a A4 harness on my 6 speed.
I see toward the rear of the 6 speed I have 4 sensors, 3 on the driver side and 1 on the passenger side. However on my A4 harness I only have two connectors and one of those connectors is the round connector that has the 2 slots in it. where do I get the other connectors for the other 3 sensors???
thanks
thanks
You'll have a vehicle speed sensor (VSS), CAGS solenoid, reverse lockout solenoid, and reverse light switch.
You can use the VSS from the auto, but you may have to extend the wires or cut them out of the harness to get the plug to reach. You'll have to wire the others. Check your PMs.
