stock A4 shifter removal
Old 05-23-2009, 07:33 PM
tording99Z28's Avatar
Default stock A4 shifter removal
I am going to be starting my TH400 swap. I want to try and use the stock shifter, I have read posts where everyone says to remove the gate mechanism between 1st and 2nd after removing the shifter, my question is exactly how do you remove the shifter? There is a mess of rods and cables. Which bolts actually hold the shifter in and how many are there? Thanks in advance.
Old 07-12-2009, 07:30 PM
Gordon0652's Avatar
bump, how do you remove the plastic center console from the shifter?
Old 07-12-2009, 08:00 PM
Gordon0652's Avatar
Never Mind...
https://ls1tech.com/forums/automatic...b-removal.html
Old 07-13-2009, 03:40 PM
trans2000am's Avatar
ya removing the center console is a bitch
Old 07-13-2009, 07:16 PM
Gordon0652's Avatar
Wasn't that bad. 15 minutes at the most after i got the **** off.
Old 07-13-2009, 10:02 PM
ya getting the **** off was the worse part i was about to bring out the saw lol
Quick Reply: stock A4 shifter removal
