TPS Sensor Wire Quick Question
Finally starting to get my install underway. I have a nitro dave electronic ws, and you need a tach feed and tps sensor +5v feed. Now i see most people go to the coil pack for the tach and right off the tps sensor itself for the feeds.
I had my shiftlight tapped into the #10 pin right off my computer for tach, no reason i can't add another wire and feed the window switch from the same spot? And the tps sensor comes in at #24, any reason i can't tap into it there instead of at the sensor, voltage should be equal all the way? trying to make everything neat
Thank You!
Thank You!
