General Maintenance & Repairs - speedometer
lonala
05-24-2009, 11:16 AM
My speedometer is off by 10 mph can i adjust this ?
wssix99
05-24-2009, 07:37 PM
Yes, the needle just pulls straight off of the post.
Does it show 10 mph when you are at idle?
Formula413
05-25-2009, 08:53 AM
Is it off by ten mph all the time, or is it off because you have different rear gears and the computer has not been reprogrammed for them?
lonala
05-29-2009, 06:31 AM
Thank you for you replies . It is 10 mphs slower and i have not changed gears.
Formula413
05-29-2009, 04:11 PM
In that case the second post is correct, take the cover off the gauges and gently pull the needle off. You may need to get a flat screwdriver under it for leverage, but be gentle.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
