Crankcase ventilation
Ok ya'll,
Anyone know of any benefits or downsides to replacing the factory oil fill cap on a 98 LS1 with one of the K&N breathers??
I have heard about oil consumption issues with LS1's however, have not personally experienced any abnormal loss on my engine. I bought the breather today... but thought I'd get everyone's .02 before I ripped it open and put it on.
Kev
Kev
breather
Originally Posted by K9Kev
Ok ya'll,
Kev
Kev
I would like to hear the results
Question : does it have the threads to screw in ?
John
LS1Tech Co-Founder
What mods do you have?
I had a Metco breather before.
I liked it but sometimes, due to the angle, it would drip a little oil on the header.
I think Metco needs to make the breather go straight up.
I bought the K&N breather and was just planning on putting it on where the oil fill cap goes. Would this be Ok ? As for now, our mods are: Air lid, Free ram air, and a dynomouth. Thunder Racing is providing a TR 224/112 for the car in the next few weeks and we are looking at headers. Not to mention all the suspension mods that Lou helped with...wow!! Handles like a slot car.
Thanks for getting back to me, I look forward to your ideas on this.
Kev
Just adding the breather does absolutely nothing except changing the fresh air source for the crankcase to where the breather is installed from the hose on the front of the passenger side valve cover that runs to the throttle body in front of the butterfly. Explain to me how this will have anything to do with oil consumption. The problem with oil consumption through the PCV system is not the fresh air source, but the baffle in the valve cover where the vaccuum is pulled. You also say you do not have an oil consumption issue so why add a breather.
I, like most people I would assume, am trying to make decisions about modifying the car to perform it's best. I appreciate your information on oil consumption and how it is caused however, not necessarily your way of telling me
If I wanted to feel like an idiot I wouldn't ask questions of all of you and would just go down to the local speed shop, load up on whatever parts some snot nosed kid said I needed, and be oblivious to the world. Instead I came here to get peoples input....thanks for the kick in the nuts!
Aw, thicken your skin up a little bit. I told you what a breather will do and the "explain to me" part is directed to all those that are telling you they have done it or to do it. It was not my intention to kick you in the nuts. If you will notice, no one told you what just adding a breather, while keeping the rest of the PCV system unchanged, will do for you.
Since I have seen nobody post a benefit of the breather over a properly working pcv system(not using oil), I'm going to have to go with the "don't fix it if it isn't broke" comment. Now if there was a gain to be had then that phrase would not apply.
2X,
Ok, I just took you wrong. There is a local place here in DFW that a few LS1 owners congregate at. I have listened to them and thought some of their ideas may have merit. Everyone has opinions, and I enjoy the input, I just have to figure out what works best for my application. That's why I'm here.
I figure that it is best to go with the 'Ain't broke-Don't fix' as stated. If and when oil consumption becomes a problem, I'll pm ya and maybe you can assist me with a fix solution. Deal ?
Thanks,
Kev
Thanks,
Kev
Quote: "Just adding the breather does absolutely nothing except changing the fresh air source for the crankcase to where the breather is installed from the hose on the front of the passenger side valve cover that runs to the throttle body in front of the butterfly".
____________________________________
Ditto what '2xLS1' says ...
Oil consumption will also be caused by P-ring blowby as the stock rings can become unseated due to high crank case pressures. (CURE: Get better rings and vent that bitch.)
Oil consumption due to PCV story can be remedied in various ways
*Catch can
*putting PCV uppright inline with fuel filters and a few T connectors.
*LS6 valley PCV system
To mention a few, however i think all of these are not 100%, but will reduce it dramatically.
My2bits
*Catch can
My2bits
LS1Tech Co-Founder
I'd only run a breather on a cammin' or otherwise modded car where you need to alleviate crank case pressure.
I am currently running a custom breather setup I made because of my supercharger.
I also have crank evac kit I could put in the car so I might do that in the near future and test it.
