Anyone had this problem?
Old 05-24-2009, 12:00 PM
97' Formula's Avatar
Default Anyone had this problem?
ok i got a 98' T/A it was a A4 and i swapped it to a M6, and i just got it on the road about 2 weeks ago i got the brake in miles on it so i go to the track to make some n/a passes yesterday and i put my et streets on the back and the cars traction control starts kicking in and want let me do a burnout or launch or anything. i put the street tires on and it will let u power brake the **** out of it. so is the 26 by 11.50 on a 16 doin something to trip the traction control because they are taller than the stockers which are 275 40series on a 17. i just need to know what yall done to fix the problem basically i want the damn traction control off all the time its useless to me for what i'm doing with the car. and thanks in advance guys
Old 05-24-2009, 05:02 PM
Cape T/A's Avatar
You have to turn T C off before you do a burnout. Its designed to not let you spin.
Old 05-24-2009, 05:23 PM
lol sorry not trying to be a smart *** but do u honestly think i didn't know that i had it turned off but it starts kickin in by its self on the slicks but on the stockers it don't kick in when its turned off so i need to know if the taller tire is sending a bad vibe or whatever........someone has to know whats goin on.
Old 05-24-2009, 05:36 PM
Restricted User
willyfastz's Avatar
Unplug the sensors on the backing plates and just leave them unpluged. That should disable the TC/ABS.
Old 05-24-2009, 05:40 PM
ok ill try that.....so u mean just unplug the wired adapter that runs to the back of the panel were the button is? Thanks man
Old 05-24-2009, 05:48 PM
Restricted User
willyfastz's Avatar
No, I was saying you can unplug the sensors that are on the brake backing plates. That way all you have to do is reach behind the tire and unplug them.
Old 05-24-2009, 05:53 PM
gotcha thanks man ill give it a try.
