Where is the fuel pump relay on '99 Bird?
Hi to all!
I am trying to find the fuel pump relay on my 1999 Formula. I am having a fueling issue and my next step is to replace the fuel pump relay. I already changed out the fuses located on the driver side engine bay. Car will not start. The fuel pump does not 'buzz" anymore before starting.
I want to replace the relay to see if this is the problem. I thought it was located on the driver side inner kick panel. I took the panel but I could not find it. Any help is appreciated. I tried search but it did not help.
Thank you all.
Thank you all.
Relay
Hi to all!
Thank you all.
Thank you all.
I already checked and changed the fuses on the driver's side under the hood. I am looking for the other fuel relay. On the '93-'97 birds the relays are on the inside driver side kick panels.
Thanks again.
Thanks again.
Found the other fuel pump relay!
I found the other fuel pump relay . It was on the inside passenger side kick panel. You have to take off the second cover under the dash. It is mounted on the left inside on the metal brace. It is a little hidden but it is there.
It looks like the ones in the engine compartment but bulkier. Hopefully this will fix my problem. If not I may need a new fuel pump.
The following users liked this post:
Jordan A (12-26-2022)
