How Do I Get My MPH Up?
in 10/2007 with my cam only car, slipping stock LS6 clutch i ran a 13.1 @113.
Today same car same set up only now i have a Tgextralia Z grip and i ran a 12.5 @ 116.... I was hoping to trap at 118..
I only gained 3mph How do i gain more MPH?
7. Rolling resistance slicks vs. radials
8. Why the hell are we doing numbers???
9. Want to go faster, get some mods.... Like tires, 12.5 @ 116 is horrible... What was your 60'?
116 is a fine trap for a cam only, stock weight car.
You might want to drop some weight, and see what happens.. and give us your 60's..
I am running 125mph traps @ 418 rwhp... losing weight helps alot. I should actually be in the 127-128 range next time out, dropped another 200+ lbs last month....
Honestly I think 116 is pretty good for a full weight car and average DA day.
Well if you shift 4th you wont be as high in the power band going across the finish unless you have gears. Was your cutout open? Are the wheels you have heavier than the ones last time you went to the track?
So i dunno what the weights are, but i would say the TTMs are hevier for sure
