Pro-Kit or Sportlines
I can't decide which would be better suited for me, so I need your opinion/help.
Car is 2001 WS6 daily driver. I have a set of QA1's ready to go on but stock springs are too tall. Eibach web site say Pro-Kit = 1.2" front/rear Sportlines = 1.6"front / 1.4"rear.
What have you guys experienced as far as settling with these sets?
Will the 1.2" drop from Pro-Kit be enough for the QA1's?
I plan on doing headers in the future and don't want to be draging them along
Thanks in advance for the help
If you're planning on doing longtubes, definitely don't go for the Sportlines. My drop with ProKit springs was 1-5/8" at all 4 corners. Most get at least 1.5" from it. Sportlines will likely drop you closer to 2" and the Eibachs are a soft enough spring that you will be bottoming out the rear even with just the ProKits. I imagine it would be even worse with Sportlines.
Based on my experience, of the two Eibach options, I would highly recommend the ProKits over the Sportlines unless you're strictly after that slammed look for some reason.
Thanks, So I can expect about 0.3" of settlement in the ProKit Springs. then I guess I need to know if close to a 1.5" drop will be enough for the QA1's
Anyone else.........
My prokit definately dropped my car more than was advertised. I would say an easy 1.5" up front, and 1.75" rear (at least). If you're going longtubes, I would definately stay away from the sportlines. By the way, the drop I mentioned is what the springs sat at when I installed them. I didn't experience any noticable sagging with time.
Jeff
Jeff
I agree w/ the others, you'll run into problems if you get the sportline's. I have a couple friends that are regreting having those springs and long tubes. Especially with SLP's longtubes. The SLP LT's sit approx. 1 inch lower than my hookers! . Go w/ the pro-kit most definetly!
Customizing Director
I have the sportlines and love them. I wouldn't change them for anything and LT headers aren't a problem at all if you do your research and get the right ones. I pretty much never bottom out with me sportlines, you just have to be a careful driver and know what you can and can't take. Pacsetters with a custom y-pipe will fit good .
SLP headers have the worst ground clearance, so it was just dumb for those people to get those and lower the car that low. If I had SLP LT's I would be worry about it being any lower than stock.
