Bigger pump than a 255 for in tank?
Old 05-27-2009, 01:53 AM
AutomagicLS1's Avatar
Default Bigger pump than a 255 for in tank?
Does anyone make a bigger pump than the walbro 255 thats in tank? I heard there is a walbro 340 or somthing out there
Old 05-27-2009, 05:14 AM
poconojoe's Avatar
You can always use a dual in the tank pump kit
Old 05-27-2009, 10:43 AM
Nasty N8's Avatar
340 is the part # for the 255lph pump. We offer a dual intank pump setup that could be right for you or I have many options. Give me a call I will help you spec what is right for your setup.
Old 05-27-2009, 07:46 PM
LS1TECH Sponsor
Lonnies Performance's Avatar
The dual pump setup should suit you nicely if you are running out of pump. There are hundreds of my kits in use with excellent durability & quite a few are supporting well over 1000rwhp.
