how to adjust McLeod street twin pedal
Ok I got my Street twin in a couple weeks ago, only complaint I have Is how far you need to push in the petal while in 1st gear for the car not to roll at a stop. Seems it almost needs to be at the floor, but shifting gears while move only requires little pressure maybe 1/4 pressed.
I have the Street twin, adj master, and flywheel, any way to adjust it?
Thanks
Mike
Thanks
Mike
I recently just went through the same issues with my car. I put a ST in about 4 years ago when I did my A4 to M6 swap. Just recently I pulled the tranny to have it rebuilt and assumed the clutch was still in great shape as the car has only had about 6000 miles put on it since the clutch was installed. Pulled the clutch to replace the pilot bushing and found the disk closest to the trans to be worn to the rivets. Never had any noticeable problems with disengagement but the clutch was not totally disengaging causing the wear.
Long story short I sent the clutch back to McLeod for a rebuild and now have it reinstalled. With the rear tires off the ground I made sure there was no rear axle rotation with the trans in 1st and clutch pedal pushed all the way in. My clutch and brake pedal are in line with one and other in their free position. With the original ST the clutch pedal was behind the brake pedal by about 3/8 of an inch. Not sure if the pedal placement is relevant or not. I adjusted my master cylinder until I got total disengagement, which was about 1 full rotation of the rod end on the master cylinder for me.
Thanks
Mike
Thanks
Mike
