street lite fitment
Old 05-27-2009, 10:32 PM
darknight02's Avatar
Default street lite fitment
ls1 f-body, with stock but ground rear cals. they fit welds, will they fit the regular 15 x 10 street lites?
Old 05-28-2009, 01:13 PM
Camaro396's Avatar
I don't think so.
Old 05-28-2009, 02:45 PM
mattl31's Avatar
not the regular 15x10's. they have to be the fbody specific ones.
Old 05-28-2009, 03:55 PM
even if the calipers are ground down to fit weld prostars? ordered a set from summit last night, didn,t know that they even made a 15 x 10 that would fir the f body breaks untill after i bought them. hope they will clear. i'll let a know either way.
Old 05-28-2009, 04:25 PM
marksboy7's Avatar
Anyone know if the regular 15x10s will work with a shortened rear? I plan on getting a rear shortened about 1.5" on each side. Just wondered if they would fit.
Old 05-31-2009, 09:25 PM
no go! even with the ground down calipers there still .5" to tight. back they go!
Old 06-01-2009, 01:08 AM
Dragwheelz.com's Avatar
I fitted a Lt1 car with a narrowed rearend and put a 5.5" wheel on it and it fit without grinding.
With a Ls1 rear caliper The grinding you have to do you might as well just remove your calipers to fit the standard wheel. This is 1 of the reasons the F body Spec wheel was produced.
The fronts require Minimal grinding to fit.
Old 08-20-2009, 01:59 AM
wmcraig's Avatar
what about 93 lt1 calipers arent they smaller?
