HELP!!! hydraulic line disconnect tool needed!!!
Old 05-29-2009, 05:25 PM
BLK00M6's Avatar
Exclamation HELP!!! hydraulic line disconnect tool needed!!!
I need the disconnect too for the hydraulic line that goes to the slave cyl. I will rent, borrow, or buy if necessary but I really only need to use it once to finish the install of my ls2! any help would be great... I live near Jersey Village, right down the street from the horse track in Houston. If anyone happens to have o2 sims I need those as well.
THANKS!!!
please pm or email me at mestemaker.ss@gmail.com
Old 05-29-2009, 06:27 PM
DONAIMIAN's Avatar
If I was in town I would help as im at 290 and Eldridge.
You might be able to rent the tool at one of the local part stores, I would check there. However I got my old stuff disconnected with a screw driver to push in the plastic sleeve.
Old 05-29-2009, 06:48 PM
RARON455's Avatar
what I do everytime Is use 2 flat tip screwdrivers and push the white releasing ring into the housing. push even and hard and make sure you dont get it into a bind, because it is not a solid ring, once you get it in far enough just pull a little and it should pop off.
Hope this helps.
FYI: if you are not sure of how the connection works,the hydraulic line is like a fuel line connection, there are some retaining rings inside the housing that have to be depressed to release the hose.
Old 05-29-2009, 06:51 PM
ZMONSTER!'s Avatar
Same here, two flathead screwdrivers.
Old 05-29-2009, 08:51 PM
BarneyMobile's Avatar
I use a pair of long needle nose pliers to push the release tab in. works like a charm
Old 05-29-2009, 09:08 PM
4150's Avatar
I used two flat head screwdrivers, mine was a complete bitch but that was probably because I had never done it before. Follow RARON455 instructions and you'll be good to go.
Old 05-30-2009, 12:01 AM
gorace's Avatar
Thats funny I just use my fingers, just push in and hold the ring and pull the hose out.
Old 05-30-2009, 12:03 AM
gorace's Avatar
I have a set of simulators also let me know If you want them they're brand new in the bag I got them from speed inc, 50 dollars shipped they have never been used.
Old 05-30-2009, 03:45 PM
BLK00M6's Avatar
Lightbulb so...
As it turns out, the plastic ring that everyone has told me to just push in with screwedrivers etc is missing... I assume that piece was damaged or removed before I got the car so that kind of blows. It looks like I am just going to carefully cut the female end of the fitting off altogether and poke the remaining male end into the slave fitting on the side of the trans
here are pics, if anyone has any suggestions, please keep em coming... I have had a lot of help from this board and am very appreciative of that.
THANKS!!!
Attached Thumbnails HELP!!! hydraulic line disconnect tool needed!!!-line-resized-1.jpg   HELP!!! hydraulic line disconnect tool needed!!!-line-resized-2-may-too-big.jpg   HELP!!! hydraulic line disconnect tool needed!!!-line-resized-3-may-too-big.jpg   HELP!!! hydraulic line disconnect tool needed!!!-line-resized-4-may-too-big.jpg   HELP!!! hydraulic line disconnect tool needed!!!-line-resized-5-may-too-big.jpg
Old 06-10-2009, 06:49 PM
kobraa's Avatar
Okay so I know we are talking about taking the hydraulic line out, but how the hell do you put it back in???!! I can't push down on my clutch because i cannot connect it. Does anybody know how to put it back in???
Old 06-10-2009, 08:01 PM
618HAWK's Avatar
Found these work great and you get 6 in a pack with a few different sizes
"HELP!" Products # 74016 Brake clutch bushings.
Was able to get them at Autozone, with a few days wait for special order. I would think anyone who sells the HELP line would be able to help you out.
I looked for the OEM ring, can not get just the ring, need to buy the full line.
Old 06-11-2009, 06:59 AM
Internet Mechanic
BlackScreaminMachine's Avatar
Yea I have used pliers before as long as there is equal pressure, your fine.
Old 06-11-2009, 08:57 AM
PewterScreaminMach's Avatar
If that plastic piece is missing you're gonna need one. But if you've got one, a pair of needle nose pliers works for me every time.
Old 06-11-2009, 01:15 PM
BLK00M6's Avatar
Thumbs up I win
So i ended up just using a dremel with a cutoff wheel to hack that lil f*cker off and I drove the car around the block yesterday. I discovered a few things; I need to rebleed the clutch, I have 2 coolant leaks at the crossover and the plug at the back of the head, and the hood's pissant mounting brackets were attached to the hood with a no-longer-present epoxy and will require more effort than I thought to line up.
BUT
Thank you to everyone who contributed, this forum is and has been the ****!!!
Old 06-11-2009, 02:49 PM
Dal1as's Avatar
Wish I had seen this thread. You don't actually need the stock ring but need some sort of bushing to push in to release the connection. I found a few years ago after using various tools and bushings that those "Help" brake bushings work perfect.
Old 07-02-2009, 03:03 AM
metalmechanic's Avatar
i actually found the tool at Napa,,
Quick Reply: HELP!!! hydraulic line disconnect tool needed!!!
