General LSX Automobile Discussion - Fob Programming
RikkiTorment
05-30-2009, 06:48 PM
Does anybody have the instructions to program a 2000 Camaro? My car came with a remote programmed for a different car and I don't want the alarm to keep going off everytime I enter with the key.
Daryn
05-30-2009, 06:58 PM
1. Turn ignition off. Remove RADIO (fuse No.17) from fuse block. Cycle ignition switch from OFF to RUN positions 3 times within 5 seconds until door locks and hatch release cycles, indicating Body Control Module (BCM) is in programming mode. Leave ignition switch in RUN position.
2. Press both LOCK and UNLOCK buttons on remote control door lock transmitter for 16seoncds. Door locks will cycle once, confirming transmitter code is programmed. Door locks must cycle completely to unlock before proceeding. Any transmitter code that was previously programmed has been erased. BCM is now programmed to remote control door lock transmitter.
3. When programming BCM to match remote control door lock transmitters, first transmitters code matched will be stored in memory unless a second remote control door lock transmitter is matched at the same time. If programming BCM to match a second remote control door lock transmitter, repeat step 2). This must be done before RADIO (fuse No. 17) is reinstalled. Turn ignition off. Reinstall RADIO (fuse No. 17) to fuse block.
philsblwnz28
05-30-2009, 07:00 PM
pull radio fuse
cycle key on/off 3 times
trunk should open
hold lock and unlock button on your fob for 20 sec
djkeene16
07-28-2009, 11:13 PM
what about like the hatch buttons
Pitbull329
07-28-2009, 11:21 PM
Same process.
I bought a new key fob since my car didnt have it. Did the steps mentioned above. Everything worked. lock/unlock/open hatch/panic
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
