thermostat area leak ?
Old 05-31-2009, 12:02 AM
killagt's Avatar
Default thermostat area leak ?
I found a leak on on the thermostat area, does it have oring or gasket ? car is not over heat or anything, just that leak, should I get another thermo while im at it ? do I need to drain coolant ? thanks
Old 05-31-2009, 12:04 AM
LS6427's Avatar
O-ring.
No need to buy another t-stat.
Old 05-31-2009, 12:17 AM
killagt's Avatar
can I change it without drain the coolant or burge the system ? what coolant do i need to use, it have green coolant in it right now.
Old 05-31-2009, 12:36 AM
LS6427's Avatar
No, you will lose some coolant taking the housing off. No big deal though, just fill it back up.
Old 05-31-2009, 12:48 AM
killagt's Avatar
thanks
