HSW relays
the microedge will have one wire that splices into the relay for the Nitrous solenoid...so there is no relay specifically for the microedge. You will need to run the purge solenoid off a different relay otherwise as soon as you spray it will purge at the same time...no good. If you have a heater then it will also have to been on a different relay. I suggest just taking the directions and looking at the diagrams and map it all out in your head and plan on how you are goin to set it up in the car. I am working on my install now as well from HSW with the sudden impact wet kit, interface, microedge, purge, and bottle heater.
Guys, theres no charge for wiring diagrams on HSW products if you need them. I know others out there do charge, for you guys using HSW products, just shoot us an email and we'll make sure your setup.
As mike put it...they have diagrams
All I did is just use them and they are very detailed. I ended up putting the bottle heater relay in the trunk under the bottle mount where the spare tire was. I put the purge and nitrous/fuel relays behind the computer to keep them hidden. I also ran the wire through the firewall using an existing gromet. Im putting the interface in the engine bay on the right hand side behind the fuse boxes and I ended up putting the microedge in the glove box.
