Need help asap!
Old 05-31-2009, 02:31 PM
Bo's 98 TA's Avatar
Exclamation Need help asap!
Ok guys I do not have any brake lights or turn signals, when I unplug the third brake light i then have no tail lights, if i plug it back in then the tail lights are dim but still no brake lights or turn signals, need help.
Thanks
Old 05-31-2009, 02:54 PM
Mike in LA's Avatar
Did you check ALL your fuses?
Old 05-31-2009, 03:06 PM
Bo's 98 TA's Avatar
Yes, I checked all of them under the hood and in the car, would it have anything to do with the flasher thing under the steering colum.
Old 05-31-2009, 03:09 PM
2001CamaroB4C's Avatar
depends...do your front drl's and blinkers work?
Old 05-31-2009, 03:57 PM
Bo's 98 TA's Avatar
yes they do.
Old 06-05-2009, 04:32 PM
Bo's 98 TA's Avatar
Still need help ASAP please if anyone knows anything please help me.
Old 06-06-2009, 07:21 AM
1QUIKTA's Avatar
I found in one TA that is was the blinker control switch in the column. It seems to control everything. Sounds like a short in there. Move your steering column tilt up and down with a buddy behind the car and see if you can get them on.
Old 06-06-2009, 07:22 PM
Bo's 98 TA's Avatar
ok I will try that thanks for the info.
Old 06-06-2009, 07:35 PM
if your front blinkers work then its not the turn signal flasher...it seems to me you have a ground issue.
if you check in your rear hatch, if you pull out part of the carpet in the bottom area around the locking mechanism in the hatch, on the driver side, just next to the mechanism is the ground for the rear lights, check that to make sure its grounded.
Old 06-07-2009, 08:59 PM
Bo's 98 TA's Avatar
Ok I will try that now thanx
Old 06-07-2009, 09:27 PM
DC Motorsports's Avatar
You been doing any wiring or moving of any panels?
Old 06-08-2009, 04:17 PM
Bo's 98 TA's Avatar
OK guys I got the problem fixed it was the ground wire in the trunk under the carpet by the trunk lock, so thanx alot for the help.
