Zero Oil Pressure
Old 05-31-2009, 03:04 PM
PongoX11's Avatar
Default Zero Oil Pressure
Can a messed up O-Ring make Zero oil pressure? I remember a while back a friend did a cam install and the o-ring got pinched and it made really low pressure.
Car had been sitting for quite a while, and just got put back together.
I drove it, ran fine and had good oil pressure.
Turned it on again and now there is zero pressure. The Oil Pressure Sending unit does not feel broken, but I'm willing to buy a new one of need be.
Any thoughts on the problem? Is there any way to manually check the oil pressure? ie: Verify there is oil pressure, so it must be the sending unit.
Thanks
Old 05-31-2009, 09:12 PM
charlie c5's Avatar
Yes sir, a messed up o-ring will kill your pressure, but since you have already run the car once and the pressure was fine, kinda throws that idea out.
Old 06-20-2009, 08:45 PM
Canadianbacon's Avatar
lol, newb. You must be getting the car ready for a real badass guy.
Old 06-20-2009, 09:04 PM
ramdaspadhye's Avatar
Old 06-20-2009, 09:05 PM
you can take the valve cover off and see if its squirting oil?
Old 06-20-2009, 10:07 PM
PongoX11's Avatar
Problem is figured out and Canadian Bacon is buying the car
Old 06-21-2009, 01:27 AM
lol, sorry Ram. I've known pongo nearly 8 years. Its an inside joke, and i am the guy buying the car. spending money on it like a drunken sailor i might add.
Old 06-21-2009, 02:59 AM
lol, mkay. i was like, this jackass with 1 post is callin this dude a noob?? lol
Old 06-21-2009, 08:41 AM
lol, i understand. i would have done the same. I'm the newb to ls1tech. but been a member with pongo on another site for a long long time.
