LT1 long block
LT1 long block
Hi,
I'm new to this site, not sure if this is the right spot for this question. I'm the original owner of my 1995 Z28, I think I just spun a bearing in the motor. I am thinking about a new LT1 long block and swapping the rest of the components. Trying to find out of the GM P/N 88894195 is a LT1 long block or older vortec long block. Found the part on genguinegm.com Also, is the only way to pull the engine from under the car by dropping the cradle. I would like to minimize the cost of the swap, and if I need a lift to drop the engine its going to be costly. I won't beable to do the work myself. Thanks.
