Another Connector ID Request
Old 06-01-2009, 07:33 AM
dpd069's Avatar
Default Another Connector ID Request
I traced this back to the PCM connectors and looked it up on the pin-out that I have, but the document says this pin is "not used"
It is off of a 2003 LM7 truck motor
Can anybody tell me what it is? The wire colors are tan, gray and black. Black connector, yellow dust boot. Three pins arranged in a triangle (not flat across)
Attached Thumbnails Another Connector ID Request-connector-001.jpg   Another Connector ID Request-connector-002.jpg
Old 06-01-2009, 10:04 AM
V8Rumble's Avatar
On my engine (2008 L92) that's the oil pressure, it attaches immediately behind the intake manifold. Same color wires, except that my "tan" wire is "tan w/ white stripe"...
HTH.
Old 06-01-2009, 10:29 AM
dpd069's Avatar
Well the oil pressure connector is MIA, so I think you might be right!
Time to get out a flashlight and a mirror and check it out.
Many thanks for your help.
Phil
Quick Reply: Another Connector ID Request
