Western Members CA, AZ, NV, UT, CO, NM, HI
View Poll Results: Do you think the car will start
Yes new pcm + tuned should start
0
0%
No - The security light will come on no start
20.00%
Not sure its a 50 / 50
20.00%
Have no idea !
60.00%
Multiple Choice Poll. Voters: 5. You may not vote on this poll
Has this ever happend to anyone with there car.
Old 06-01-2009, 12:04 PM
Tapout97's Avatar
Default Has this ever happend to anyone with there car.
Ok, so a few weeks ago my car check engine light came on right before i went to the track and it went from a 12 sec car to running 14.0 trapping anywhere 8-11 miles slower. OBD TECH 2 showed 4 codes
p0100 p1657 the other 2 had to deal with o2 sensors , skip shift 1-4 then it was blowing the fuse in the engine sensor
since then i had it checked out to see if any electrial wires toasted they couldnt find anything. So they put in a 25 amp breaker fuse in.
so the car runs like crap then all of a sudden a week later the electric water pump goes out. I put a new one in and we noticed the electric water pump was connected to the pcm . So i bought a new electric water pump the car ran for 4 minutes then it died then the SECURITY LIGHT came on BLINKING the car woudlnt start at all. I contacted bryan @ pcm4less told him everything and he said flat out your PCM is F$C^E% so i managed to find one after searching all over the internet nobody had one called gm got the only one in the state threw brown and brown cheverlot in AZ. $208 bucks not bad. Its been sent off i should have it in 2 days.
Heres the question im having the VAT turned off do you think the car will start up or will the security light still be on and i wont be able to start the car ?
This isnt a tech question really im curious if anyone else has experienced the same.... COME ON GUYS SOMEONE HAD TO HAVE HAD THIS HAPPEN TO THEM
Old 06-01-2009, 12:49 PM
ss.slp.ls1's Avatar
You should have asked me, I have a '97 PCM in my garage.
Who wired up your EWP?
If you have VATS tuned out in the PCM, the computer will no longer need the signal from the BCM to enable fuel delivery. However that will not allow the starter relay to work properly if you have a faulty key or bad ignition cylinder. Only way to know for sure is to get your new PCM in and try and start the car.
Old 06-01-2009, 08:03 PM
Tapout97's Avatar
ttt come on peeps help out another gm guy here !!!!
Old 06-01-2009, 08:09 PM
Tapout97's Avatar
T.t.t
Old 06-01-2009, 08:57 PM
primer84z's Avatar
Put the steering wheel in a rear naked choke and it should fire right up.
Old 06-01-2009, 09:49 PM
mikejones's Avatar
lol...good idea. Dont forget to yell at it and try to act hard in front of it. Then in the end try to tell it to forget about it and move on....
Old 06-01-2009, 10:55 PM
XpEdItIoUs's Avatar
LMAO, also try punching the hood a couple of times as warning shots. Then tell it how highly skilled you are at MMA and tell it you want it to run 10's or else there will be trouble.
Old 06-01-2009, 11:57 PM
CaliforniaBoy5's Avatar
he just needs to make sure he does all this at the pavilions or else its not cool and make sure his buddies are around for back up.
Old 06-02-2009, 11:16 AM
Tapout97's Avatar
Lol @ how tuff i m :lol this is aobut the car no not al **** talkers you ls1 guys need to relax ....anyones has this happened to your carr beffore
Old 06-02-2009, 08:24 PM
Tapout97's Avatar
Originally Posted by lt1formula275
ok heres a story that might help i go to get in my 95 formula and i put the key in and it does nothing wont even turn over so put a switch in didnt fix it, turned vats off didnt fix it but finally i found a relay/fuse think behind the dash on the passenger side and hooked two pieces of wire together and it fired up but the secrutiy light is on but after 5 minutes of driving it goes away
anyone know about a relay fuse behind the dash if so 3 things
1. what should i be looking for
2. where exactley is it located at
3. once found what do i do ?
Old 06-03-2009, 04:55 AM
Tapout97's Avatar
come on guys im sure this has happend to you please help !!!!!!!!!!
Old 06-04-2009, 01:30 PM
Tapout97's Avatar
T.T.T Someone has to know a thing or too .............................:d
Quick Reply: Has this ever happend to anyone with there car.
