Pressure Plate Bolts
So when I was taking down my transmission I thought it would be a great idea to just throw all the bolts in one big box - the problem now is trying to figure out which ones go where. Using the process of elimination I've come to the conclusion that these are the pressure plate bolts (pressure plate to flywheel bolts):
However, the first bolt I tried to put in snapped, so if these are indeed the right bolts, where can I get more? What is the ARP Part number for them?
They seem to have just enough thread if you look at the second picture I just added.
Kleeborp the Moderator™
Ahhhh...missed that part. Looks like they are the right ones from the second pic, but I'm not sure where you would source them. You might try calling Thunder Racing, Speed Inc., etc. to see if they might be able to help. A quick Google search didn't net me anything...
Turns out I broke that one because I was trying to torque it to LS1 specifications (55lbs) instead of LT1 specifications (25lbs).
ARP says part number 230-2202 is for their pressure plate bolts. I'm going to check with my local ARP dealer to double check.
EDIT - ARP will tell you the 230-2202 number, but it doesn't seem to be the right bolt at all to me. Both bolts they list for various years, including LS1's which I know use a different bolt. Also, they list the bolt as being 1" long, the LT1 bolt seems to be about 1.5".
You probably could...I'd try to find one with as much grip length (unthreaded part of the shank) as you can to sort of match the stock bolt, but a little longer thread length doesn't look like it would hurt in this application. It should probably also have the flanged head like the stock piece.
I'd also get as strong of a bolt as you can find in that size...grade 10.9 if it is metric.
BMW ///M Nerd
Bring it to a hardware store. Looks like a 10mm bolt, 1.25, or 1.5 thread pitch. Hard to say with a picture. Just measure it out with the ruler they have at a good hardware store and get a hardened bolt. Needs to be flanged, don't go longer/shorter without measuring/checking the flywheel for clearance, etc.
Also, be sure to loctite these bolts, and then torque to spec. First tightening in a star pattern, slowly, to suck the diaphragm of the clutch in.
Pull your alignment tool in and out when your done. If it doesn't slide in/out with ease, back off the pressure plate bolts, and start over. SLOW is the key word here. Clutch alignment is the key to a good clutch install, and eases trans. install.
Here's what I was able to find:
VS Stock:
Now I have two choices:
1. Cut them down to the length of the stock ones.
2. Replace them all with the long ones.
I personally like option 2, but can anyone see any problems with it?
VS Stock:
