Ordering HOK Paint
Old 06-01-2009, 11:15 PM
blazin's Avatar
Default Ordering HOK Paint
Im ordering paint online. Here is what I have so far I want to end up with 2 gallons sprayable paint.
1.5 gallon of color mixes 2 paint 1 reducer
1 gal reducer
1 gallon of clear 2 paint 1 reducer 1 catalyst
.5 catalyst
If I read right I can spray DESIGNER PEARL BASE COAT over primer and then clear it? Also I didnt see a HOK high build primer listed. Let me know if my match is close.
Old 06-02-2009, 10:25 PM
chevcamaro's Avatar
I wouldnt put the paint over the primer I would spray sealer on first. Also you should tint the sealer so your basecoat covers faster. (using kandy koncentrate) Even though house of kolor doesnt recomend it you can reduce 1 to 1 with the designer pearls it works fine but its up to you. I have sprayed them both ways and you cant tell a diffrence in the end.
