Generation III External Engine - Oops! I broke something
SS4Luck
06-03-2009, 01:10 AM
Well I broke my ECT sensor... (the one above spark plug #1). The pins are still straight and there, but the plastic coasing that the output sensor clip fits into broke. I can put the slip over the 2 pins, and it seems to stay straight, but i plan on going to the drag strip Thursday night and im worried it might fuck something. I have solid motor mounts so its not like the motor is going to rock it off, i just wanted to know:
1) how expensive they are
2) should i get one from the chevy dealership or autozone
3) is there anything i should worry about??
thanks
Da Swami
06-03-2009, 02:15 AM
thanks
Did the same thing when I was installing my headers/motor mounts/exhaust. Smacked it with the old manifold or something.
Anyway mine was the more expensive and harder to find '98 one and I still picked it up at NAPA for like $20 I think. Pretty sure the other one (the one you need) was cheaper though.
SS4Luck
06-03-2009, 02:22 AM
yeah i need the 3 wire one not the 2 wire one
Duffster
06-03-2009, 09:52 AM
put it back in and throw some duct tape around it (maybe 3/4" wide strips) and then a heavy duty zip tie really really tight. It'll work for a while.
SS4Luck
06-03-2009, 11:34 AM
TTT for the midwest noon crowd
The Alchemist
06-03-2009, 11:39 AM
I did the same thing and went on the power tour with it taped on. Over 1800 miles with no issues. At the time I just didn't have the time to worry about it and the car ran fine. Now if it gets disconnected, it will make the car go wacky because a lot of the settings are engine coolant temp dependant like spark and fueling.
SS4Luck
06-03-2009, 11:42 AM
alrite ill get the good ol duct tape out and tape that shit up till i can find a new one. Thanks guys
LS1BLKSS
06-03-2009, 11:55 AM
i found them at autozone for... i think $20???
Duffster
06-03-2009, 12:24 PM
since you know it's fragile (not as fragile as the oil pressure sending unit) be careful on the install too :)
1Loudz28
06-03-2009, 01:09 PM
i needed a new one, got one from napa for $15 last year.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
