Critique My Kit
Critique My Kit
Alright guys I'm changing a few things around with my setup and I want to make sure everything is peachy. Here's what its going to be:
HSW Standalone: Running at 10 PSI fuel pressure
Dynotune Nitrous Solenoid and Purge Solenoid
TNT Fuel Solenoid (Big one)
Nitro Daves 78mm Plate
Dynotune RPM Window switch
AEM Wideband
TR6 Plugs
Those are the basics of the nitrous kit. Mods to the car are in my sig.
I think the nitrous kit is well set up and has good components in it, but my worry right now is that the SS4000 stall is going to be too much, and I really don't want to pull the tranny in lieu of a new converer.
The car also has katech rod bolts....so I'll most likely be shifting it at 6800.
Just looking for some opinions on the setup and what could be better. Thanks!
AEM Wideband
TR6 Plugs
How much are you going to be spraying? Do you have a fpss on the dedicated incase the fuel pump fails?
Do you have other accessories such as bottle heater, purge pressure, gauge etc.
I would try the convertor you have and see how it reacts before making changes.
Dave
Dave
If it were me, i would run high pressure on the standalone.
What size shot are you going to be spraying? Also, give us a bit more detail on your motor setup. This will help determine the correct plug for your system.
Other then what dave mentioned, it seems like your in good shape.
I had planned on spraying NO MORE that a 150 shot. Most likely a 100 shot because of the converter.
I currently have a FPSS (Hobbs) on the fuel rail since my kit was a dry shot before. I will move the FPSS to the dedicated to cover my bases there.
Running a Dynotune High Output pressure regulated bottle warmer set to 1000 psi for the bottle.
Do have a purge.
Do have a pressure gauge for the bottle.
Motor is stock bottom end. LS6 intake. P & P throttle body. cam is a 236/238 .598/.601 on a 113 LSA. Speed Density Tune. Full bolt ons (minus pulley).
Let me know if you guys need any more info!
Do have a purge.
Sounds like you pretty much have it nailed. Yes move the FPSS to the dedicated. Since the FPSS is a high pressure you will need to use the dedicated at high pressure.
I would suggest using the NGK BR7EF plugs and pull about 4 to 6 degrees of timming. The TR6 you have will work but the BR7EF is better.
Dave
Dave
Rick
Rick
ext. 121
