tremec tko 600
Old 06-03-2009, 11:48 PM
jimmy92rs's Avatar
Default tremec tko 600
I have tremec tko600 5speed transmission. I was wondering if you can bolt this up to a ls1 engine and make it work. Right now I have this bolted up to a 1st gen small block chevy, and im thinking of going to an ls1 engine in the future. Input needed, thanks
Old 06-04-2009, 05:20 PM
Billy M's Avatar
You can use our 8630 bellhousing and 8617 adapter bushing. The bolt hole at the 12 O'Clock position will not line up. The other option is 8710-01 modular bellhousing, this unit will also work for your application.
