can a 4l80e be converted from 4x4 to 4x2?
Old 06-04-2009, 08:43 AM
73 nova guy's Avatar
Default can a 4l80e be converted from 4x4 to 4x2?
well that's the question i found a 4l80e but its 4x4 and i was wondering if there is a kit to put a tail shaft on it so i can use it in a 4x2 or i am dreaming.
Old 06-04-2009, 09:19 AM
Gingervitis Addict
slow67's Avatar
Need an output shaft, a reluctor wheel (for speedo) and a new tailshaft housing. Tranny must pretty much come competely apart for this.
Old 06-04-2009, 09:49 AM
i figured just like a th350/400 same deal. thanks for the help.
Old 06-04-2009, 10:50 AM
ShevrolayZ28's Avatar
Do a google for 4L80 tail housing. There's even a couple out there that have mechanical speedo capability.
Old 06-04-2009, 12:48 PM
forcd ind's Avatar
along with all the stuff mentioned, theres a plug in the back of where the tail housing would bolt up to, that needs to be drilled or replaced with one with a hole
Old 06-04-2009, 08:32 PM
WE TODD DID's Avatar
Reluctor wheel?
Old 06-04-2009, 09:43 PM
Gingervitis Addict
slow67's Avatar
Originally Posted by WE TODD DID
Reluctor wheel?
For the speedo. Been forgotten more than once.....
Old 06-06-2009, 07:03 PM
The speed reference on an 80 picks up off of the rear speed sensor. The reluctor is made into the output carrier.
Old 06-07-2009, 07:01 PM
It is quite possible to get a 4L80 put together without the reluctor. Ask me how I know.
Old 06-07-2009, 07:33 PM
FLT
FLT's Avatar
I would not suggest drilling the freeze plug in that back of the case. There is an actual seal that is apart of this plug with an orifice in it for the 2wd models. Also on the 4x4 models the rear planet carrier can have a pressed on reluctor or it might not. If you have a model without one, sonnax sells the relutor that can easily be pressed on. Vince
Quick Reply: can a 4l80e be converted from 4x4 to 4x2?
