Those who use AEM widebands
How long is the lead from the sensor to the gauge? I want to put it on my A-pillar but the bung will be at the Y in the exhaust. Also the output for a reference signal either datalog or signal to a contoller, how long is that cable? I need to run it to a nitrous contoller to reference the AFR and if it goes Lean/Rich it'll cut the kit off.
I run an Innovate LC-1 with XD-16 gauge but a lot of my friends use the AEM unit. I'm pretty sure there's enough wire to run from the y-pipe to the a-pillar. I know my Innovate has plenty of wire. You can save some wire but routing it up through the shifter boot(the rubber one that's screwed to the body, under the column panel and up to the a-pillar.
im running the AEM. pleeeeeeenty of cable from the y to the pillar. your analog outputs for data logging will have to be soldered to the harness that comes with the AEM wideband though. its i believe 3 wires with a plug on the end. they are only about 6 inches long, so you'll just splice in some wire cut to whatever length you like.
