Western Members CA, AZ, NV, UT, CO, NM, HI
question about ls1 tensioner pully
Old 06-04-2009, 05:18 PM
hlaalu's Avatar
Default question about ls1 tensioner pully
mine is really loud, can these be greased up or do i need to replace it? thanks
Old 06-04-2009, 05:37 PM
02NBMWS6's Avatar
remove the belt, spray some WD40 in it, clean the outside off, replace belt
Old 06-04-2009, 05:53 PM
lowerthanyou00's Avatar
replace it asap
Old 06-04-2009, 06:08 PM
ss.slp.ls1's Avatar
Just unbolt the pulley and replace the tensioner bearing, it's cheap and easy.
Old 06-04-2009, 06:11 PM
hlaalu's Avatar
yup just got back from the zone, it was $14 for a new one.
Old 06-04-2009, 06:23 PM
LS1Tech Editor
loloone's Avatar
OK stupid question here, is it a squeaking sound or more of a rattling sound? My LS1 has always had this sorta rattle click sound that tends to go away once it's warm. Hasn't effected performance and heard other LS1s with the same noise, always wondered what it was.
Old 06-04-2009, 06:26 PM
ss.slp.ls1's Avatar
Easy test is to remove the belt and run the engine, if the noise disappears, there's an issue with your accessories, if not, look elsewhere...
Old 06-04-2009, 07:09 PM
SUCK MY SS's Avatar
make sure the belt is not too loose or too tight... look at the tensioner itself while the engine is stopped... is the marking too far to one side or another?
- if that is the case, you either have too long or too short of a belt...
if its in the middle, start the car and watch the tensioner to see if it is banging against one side or the other... if this is the case, the spring in the tensioner is weak and needs to be replaced..
Old 06-04-2009, 07:40 PM
MrElectric03's Avatar
Ive heard of that problem with one of the solenoids or something to do with the emisions, maybe only 99-00 but cant remember, but it only does it when its warming up, kind of like the air system.
Old 06-04-2009, 07:43 PM
NHRAMAN's Avatar
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
I spray mine with silicone every once in awhile.
Old 06-05-2009, 08:19 PM
ae13291's Avatar
even tho i greased my ac small pulley that sucker is squeaking and is driving me crazy, im gonna go get a new one.
Old 06-05-2009, 08:27 PM
ae13291's Avatar
****! i cant seem to find autozone or kragen selling the small a/c pulley. where can i find em?
