Performance Switch?
Old 06-04-2009, 06:59 PM
2000TransAm24's Avatar
Default Performance Switch?
I had a performance switch i rigged up with my stock transmission. Well since I put in my FLT stage 4 tranny my switch no longer works. Does anyone know how to rig it up to work again? I just want to use it to change shift points when im on the spray.
Old 06-04-2009, 07:53 PM
LS1Tech Sponsor
performabuilt's Avatar
Changing the trans should have had no effect on that switch. Other than if there was a vac mod installed it will no longer affeect shift firmness.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 06-05-2009, 11:47 AM
alright guess ill go back and check all the wiring. thank you
