nano question
Old 06-04-2009, 11:08 PM
TPRDFW's Avatar
Default nano question
How do i go about filling my n20 bottle without my nano attached? what fitting needs to go in on the hose from the nano into the n20 bottle???
cus im confused that the n20 will drain out if the hose is not connected with the nano attached?
Old 06-04-2009, 11:49 PM
waterbug1999's Avatar
If you put everyting on that the NANO came with, the fitting you attach your NANO hose to thats screwed into the N20 bottle has a check valve in it. So, when the N20 gets pressure, it seats and no leakage occurs.
But, to play it safe, I always have the hose disconnected from the N20 bottle. That prevents any small back surge up the hose and to the NANO regulator.
Old 06-05-2009, 12:06 AM
TPRDFW's Avatar
im only worried about filling my nitrous bottle.
no nitrous will come out of the port when you are fillin it, if the hose & nano arent connected right?
Old 06-05-2009, 12:09 AM
you have to have that check valve/adapter on the N20 bottle. If you have it all on right it wont... If you have it off, try blowing thru it both ways and tell me what happends.
My suggestion on unscrewing the hose was if your bottle is COMPLETELY empty, you get a small surge going back up thru the line and into the NANO regulator if the check valve doesnt seat immediatley. That can damage your regulator causing the pressure to shoot up. I know, it happened to me and it shot up to ~1400 psi. So, im telling you to simply unscrew the hose from the adapter/check valve so it wont happen to you.
Old 06-05-2009, 12:12 AM
TPRDFW's Avatar
what does that look like? does it go in that port? or can u just use any pipe fitting to go from the hose to the bottle?
Old 06-05-2009, 12:15 AM
No, you cant use any pipe fitting to connect the two bottles.
Old 06-05-2009, 12:17 AM
TPRDFW's Avatar
****! well i didnt get the right fitting than from nano can you show me a pic of that fitting?
Old 06-05-2009, 12:21 AM
Its just the fitting that screws into the N20 bottle. I dont have my bottle anywhere around to take a pic and show ya. Im sure if you search, there is a pic floating around.
Old 06-05-2009, 12:27 AM
TPRDFW's Avatar
ok but is there any thing special on that fitting? like a valve that does let nitrous out when you dont have the line from the nano connected? i cant find a pic btw
& thanks for ur help btw man
Old 06-05-2009, 12:29 AM
Its a check valve... Means it only lets things flow one way. So, rather you have the NANO hose hooked up to it or not, it wont let any N20 come out, only NANO in.
Old 06-05-2009, 12:31 AM
TPRDFW's Avatar
dam wow well can i get one from n20 outlet i cant seem to find it?
Old 06-05-2009, 12:35 AM
Im sure they will have one..
Trying to build your own?
Old 06-05-2009, 12:38 AM
TPRDFW's Avatar
i have everything but that and i need to get both bottles filled tomrw!!! if i dont have that check valve i cant fill my n20 bottle
Old 06-05-2009, 12:40 AM
Call some local gas (Toll Gas is where I would look) companies and ask around, or maybe grainger?? Im not sure on the certain specs (or if there is any) that it has to be, just find out the thread size and ask around.
Old 06-05-2009, 12:42 AM
TPRDFW's Avatar
Originally Posted by waterbug1999
Call some local gas (Toll gas would be around here) companies and ask around... Im not sure on the certain specs (or if there is any) that it has to be, just find out the thread size and ask around.
ya im sure some speed shops or some one has got to have it around
Old 06-05-2009, 12:44 AM
"IF" the speed shop is a NANO provider.. Good luck on your search.
