Short Belt Mod Question
Restricted User
Ok...real quick question...With the ASP U/D and Alt. Pulley....what size belt would be needed to bypass the P/S pump?
I wonder if anyone even tries to search any more? You owe me $10 for the two minutes it took me to find these posts using search.
https://ls1tech.com/forums/135356-post12.html
https://ls1tech.com/forums/362637-post3.html
I'm curious since I only have the ASP crank pulley, is the Alt. pulley an overdrive (larger than stock)? Answer this and your debt will be forgiven.
Larry
Larry
Restricted User
Larry
Larry
