Sponsored by: DashLynx
Fuel Rail Covers?
Old 11-08-2003, 02:05 PM
Fiery Features Director
Zangel's Avatar
Default Fuel Rail Covers?
I have a 1998 Camaro and I am looking for some fuel rail covers. The covers don't have to be anything fancy and I would rather not spend $200 for them. I would need to find a place that could get them to me without the 4 week waiting period. I am looking for something that will make the engine compartment look better for the car show coming up in a few weeks.
Old 11-08-2003, 02:45 PM
onyxxtreme's Avatar
gmpartsdirect.com sells the factory covers cheap as hell
but i cant find the part numbers for them
someone else will have to chime in on that
but you do have to cut the covers to fit an Fbody
Old 11-08-2003, 03:31 PM
Steve1969LS1's Avatar
Yep.. cut to fit GM covers is the only option for less than $200.. the fbody concept ones are very nice but cost $$$. People do customize the GM ones but again the cost will be higher.
You need GM covers from a 98 vette.. that way you will already have the two notches for the fuel and emissions hose..
Good luck
Old 11-08-2003, 03:39 PM
Administrator
unit213's Avatar
The C5 FRC's are a PITA in my opinion. SO much cutting to get them to fit due to EGR/AIR crap. I'd pay the money and have it done right the first time.
Old 11-08-2003, 03:54 PM
DanoHB's Avatar
Ebay motors...that is the place to get 'em cheap. Just make sure you get the right year. Some will fit, and some won't. You just have to make sure you read the sellers ad before you bid. Good luck.
Old 11-08-2003, 04:01 PM
Zangel's Avatar
Thanks a bunch. I don't want to spend the money because I will do the custom work here. I just need to get them quickly.
Old 11-08-2003, 04:24 PM
PontiacFan's Avatar
GM 12556455 + 12559261 Fuel Rail Covers.Minor cuts to fit, Most cuts will be hidden under the cowl when installed.
PM if you want more details.
Old 11-08-2003, 04:37 PM
Chop-Foo Director
PendragonZ's Avatar
I see them in the for sale section every now and then.
Old 11-08-2003, 05:15 PM
9 Second Club NA
Dragaholic's Avatar
I believe they were like $55 shipped from GM Parts Direct and it doesnt take much to customize them yourself! If you remove the AIR and EGR, it makes the job a whole lot easier. I think there was only a few minor cuts, nothing big, but you will have to chop almost half of them off if you keep the AIR and EGR. I used epoxy to fill in the CORVETTE, but theres other stuff out there that you can use. Once youve filled it in, sanded it, and repeated maybe once more, you can then use some sandable primer to get rid of all the pits/flaws. I used about 3 coats with wet sanding in between each coat. Then its ready to paint! A couple of coats of color and then a couple of coats of clear and youre all set unless you want to add some decals or whatnot. Very simple, just a little time consuming, but definately doable within a 4 week period. Hope that helps!
Quick Reply: Fuel Rail Covers?
