won't start
Old 06-05-2009, 10:06 AM
ricardo colon's Avatar
Default won't start
1998 firebird 3.8 , run was runing ok ,when i tried to satar the car , it won't start and no dash lights at all .
Old 06-05-2009, 10:32 AM
hlaalu's Avatar
check your battery?
Old 06-05-2009, 10:36 AM
battery is ok , headlights and wipper works fine
Old 06-08-2009, 11:57 PM
justout4u's Avatar
if you have power at first then nothing when trying to start it sounds like an ignition swith located under driver dash. also make sure battery terminals are tight with a wrench
Old 06-09-2009, 10:03 AM
Bad30th's Avatar
Check all the grounds yet ?
Rob (Bad30th)
Old 06-09-2009, 05:45 PM
got it fix , ot was the ignition switch , thanks , this site is better than car manual
Old 06-11-2009, 01:03 AM
justout4u's Avatar
anytime
