SparkyJJO
06-05-2009, 09:14 PM
I did my rear shocks today (doing fronts tomorrow). That actually went really well, the bolts all came off OK. PB blaster is great stuff :) While I had the wheels off I checked out my passenger side brake because I have been hearing this swishing salt and pepper sound from that wheel for a little while. Come to find it is apparently the axle bearing is bad. Spinning it by hand feels like marbles inside... uh oh.
Did a bunch of reading and searching tonight. Crap, the pulsing WRRRrrrrRRRRRRrrrrRRRR noise that I thought was tire noise from the more aggressive tread on my all-season tires for all this time was more than likely the bearing howling. With it doing it for that long and feeling that bad now I think I've probably got a shot axle as well :(
I'm not spending 200 bucks on a new axle, so I'm going to get a used one if mine is truly shot. So a few questions:
1. Will any axle from a 98+ fbody with a non-TCS 3-channel ABS work or are there different spline counts depending on the gear ratio inside the differential?
2. Does anyone know the best place to get a good used axle from without breaking the bank? Like anyone here have one for dirt cheap :) Found one on ebay for $40 + $27 shipping with less than 50k miles on it, sounds decent to me but is that what I can normally expect to pay?
3. While I'm at it, would you recommend I just go ahead and replace the driver side axle bearing now even though it feels fine, to prevent eating my axle on that side?
4. Any way to get the old bearings out without having to buy a slide hammer and bearing puller? I don't have either of those tools. I can probably rent the puller from Autozone (I'll have to check) but I'm not sure about the slide hammer.
5. If it is grinding like marbles when I spin it by hand, what are the odds the axle is still OK? I'm guessing very slim...
Thanks for any advice you can offer. With this extra cost I wasn't planning on, I'm hoping my ball joints are OK when I check them tomorrow :nono:
