Fueling & Injection - When should I replace stock injectors?
Nick D
06-05-2009, 09:34 PM
My car has ~117K miles on it. At what point do I know if the stock fuel injectors need to be replaced? Thanks.
sroach20
06-05-2009, 09:47 PM
when you add a cam and heads.
Gordon0652
06-06-2009, 01:13 AM
410rwhp through an A4. Then you need some more flow!
FICINJECTORS
06-06-2009, 04:29 AM
Your stock injectors are Bosch design III's, as long as theyre still flowing enough fuel to support your HP level, they will not go bad.
Sending them in for a full cleaning is a good idea tho.
badmfkr
06-07-2009, 09:43 AM
if you are concerned about how old they are w/ that much mileage and car burning down it would be caused by a leakie O-ring at base of injector.
if you ever smell fuel in the engine area it most likely will be a detererated O-ring.
Nick D
06-07-2009, 11:15 AM
Thanks guys, I appreciate all the responses.
