Doing a Swap on a Budget Question...
Old 06-06-2009, 10:09 PM
bad98t/a's Avatar
Default Doing a Swap on a Budget Question...
Ok, I bought a "low mile" 5.3 thats been run in another swap car probably 5 times down the track and has about 30k miles on it has had no N2O run on it just stock w/ ls1 cam. What I am wondering is, since a ring kit is so cheap and bearings arent, if I hone and re-ring this motor, can I reuse the bearings if they are all in good shape? Is there any problems I may have by doing this? Any tricks? Thanks.
Old 06-06-2009, 11:28 PM
sandking's Avatar
Why not just run it as is? 30k on the clock leaves a lot of life left.
Old 06-06-2009, 11:48 PM
71 chevelle's Avatar
x2........
Old 06-07-2009, 02:58 AM
letsrunem's Avatar
x3...
Old 06-07-2009, 08:54 AM
Stu Cool's Avatar
x4 These motors commonly last 200k miles.
Old 06-07-2009, 11:25 AM
Clothesoff's Avatar
x5...........Run it as is. If you feel you must put rings in it then change the bearings, no sense building it twice.
Oliver
Old 06-07-2009, 12:24 PM
bad98t/a's Avatar
ok makes sounds good...I was just thinking since I had to replace the head gaskets? Thanks alot
Old 06-07-2009, 04:11 PM
04600rr's Avatar
why do you have to replace the head gaskets?
Old 06-07-2009, 09:19 PM
bad98t/a's Avatar
I replaced the head gaskets because the guy I bought the motor from was running LS1 heads and for some reason he wanted them lol. So i put some new gaskets on.
Old 06-08-2009, 05:19 AM
Pop N Wood's Avatar
You bought brand new head bolts at the same time too, right?
Old 06-08-2009, 10:40 PM
bad98t/a's Avatar
havent put it back together yet but yes. another question about this is does arp make a head stud for these and would it be worth it since i will be trying to put a pretty big shot on this motor? Thanks.
Old 06-09-2009, 08:19 AM
holley505's Avatar
Yup... ARP head kit is the way to go. I have a brand new set I am selling... you pay to ship.
I have a HEAD BOLT KIT also $100.00 Firm in the box Early LS1... I needed the Other Head bolt kit 3610...didnt realize until after I got the kit.
ARP-134-3609 ARP High Performance Series Cylinder Head Bolt Kits
Cylinder Head Bolts, High Performance, Hex Head, Chevy, Small Block, LS1/ LS6, Kit
Today $149.95 from summit
Also with alot of SPRAY COMETIC gaskets are the best. I have a set for $80.00 firm
Old 06-11-2009, 08:39 PM
bad98t/a's Avatar
Thanks a ton, now the latest question... how in the hell do I know what head bolts i need? lol. the motor was supposed to have come out of a 2002 or 2003, but never saw the truck so I have no real idea? any advise on that?
Old 06-11-2009, 11:21 PM
sawzall wielding director
G-Body's Avatar
Does it have a barcoded sticker on the back of one of the heads? If it does I believe the # on there is the vin, so the dealer can decode it and tell the year.
Quick Reply: Doing a Swap on a Budget Question...
