How 2 make 4l60e last longer?
Hi,
I see the stock 4l60e tranny is a weak spot when adding extra hp, and that for some it lasts well, others not so much.
Is there a way to 'beef up' my stock tranny, affordably for the home mechanic, without a full tranny swap?
The A4 tranny looks complicated scary, and I don't really want to rip into it.
I just wondered if there is an easy couple of parts to swap out that are worth doing, to make it a bit more sturdy.
Thanks for the advise......
Okay, thanks for the advise.
I guess I may just cross my fingers, I'm possably going to eventually spray or TC &/or cam.
If the worst happens I'll do the upgrade to a 4l80e/4l85e.
I live in the UK, so getting work done by rossler isn't going to happen
There are a few tranny specialist around here, but I know they won't be cheap.
Just a shame I can't take a couple of preventative measures.
tals7
no not a must do but it would not hurt to seperate trans cooling from eng cooling.4l60e are good the just cant take the abuse as will.they are an extension of the shity 700r4 which was first put behind the 2.8/4.3 in s-10,s in the early 80,s.if you are not going to race your car i would not worry just maintain your 4l60e .
No, I don't really race this car, I've just herd about some of it's weaknesses, and wondered if there was a budget way to help curb some of the problems.
Thanks again for all your help,
Kind regards,
Paul.
Kind regards,
Paul.
If I run N2O, I will use a progressive controller to help reduce the shock on the tranny and rear end.
streetassasin, did you use a progressive controller with your N2O?
Also, how big of a shot kill your tranny?
I guess aaa card is a recovery company? lol
BTW LOL at the AAA comment. Vince
Thanks for all the input.
I'll look into those parts Vince, your right, I've not really got tonne of money I'm willing to dump into this ATM.
I'm not running slicks, but I may get 10" in the back eventually with newer tyres if the Konis don't sort out some of my traction issues.......
Man... In my experience there is no good reason to NOT have a transcooler on your system. PERIOD. After that, chage the fluid and filter every third or fourth oil change and except for the advice on the basic mechanical gear above (which I have NO idea about) as a general operator, that's about the only defense that ya have. Keeping you system cool and it got my stock 4l60E through two years of HARD racing. (I had that unit 'rebuilt' when I bought the car... with what was described to me as 'heavy duty clutches' etc... the word "Corvette" was used a LOT... )
I made nearly every Friday night 1/8th mile heads up and ran 20 or more passes every outing, with numerous bracket races on many a Saturday... And that was progressing from mid 9s to the mid-high 7s...
One note... the trans AND the stock posi hit the skids the second night after I bolted up the spray and that is only a 50 shot.
So if you're not where you can get Frank at Performabuilt Trannies to send ya Level 2... best tread with caution on squeezin' the juice. 'turns out that it can be kinda hard on ya.
