Will GM 6.0 gaskets work on a 4.080 bore?
Like the title says Im installing the heads on my LQ9 with a 4.080 bore and Im wandering if stock GM head gaskets will work. Thanks in advance!
Thanks guys. Your right I should just go with cometics. I guess Ive gotta sit down and figure out what thickness I need... I ran 6.0s last time I pulled the heads but they leaked so I questioned the GM 6.0 gaskets. Thanks again.
You should run a good .015/020 size bigger than your bore or head chamber bore (which ever is bigger)
part # 12610046 LS3/L92 gasket is what you need.
