How much should I spray it?
I have:
408 Iron block
Eagle Crank/ Rods
Wiseco Pistons w/ 1.110 CH GFX Steel rings
The New PRC 237CC Heads
Texas Giant cam
Ported Fast 90 90
Im Wanting to spay the hell out of this setup. I will be running a Racetronix Tank and Hotwire setup , and a Dedicated fuel system for the spray. I was thinking of doing the spray into 2 stages and Looking at a 300 shot?Is more possible? Im trying to Get near 900HP
408 Iron block
Eagle Crank/ Rods
Texas Giant cam
Ported Fast 90 90
You're engine from the sounds of it could take a 300 shot, I would do 200 through the direct port and 100 through the other stage, as long as you have the proper fuel, IE stand alone, you should be fine! Don't forget to run the proper plugs and pull enough timing man!
I have:
408 Iron block
Eagle Crank/ Rods
Texas Giant cam
Ported Fast 90 90
408 Iron block
Eagle Crank/ Rods
Texas Giant cam
Ported Fast 90 90
Rick
