Fueling & Injection - Injector Adapter - Minitimer to USCAR
MotleyDrew
06-07-2009, 03:33 PM
Hello All
What Adapter didi you use on your cars? I just installed my 80lb Ford Racing injectors with the Injector Adapter - Minitimer to USCAR for Ford Racing and they don't seat fully. They look like they should click right in but it get a bit more than half way and stops. This is the part that connects to the stock wiring harness. Car is a 2001 Z06.
These are the ones I am trying to use: http://www.americanmuscle.com/mustan...edium=Shopping
Any info is appreciated
Bmotorsports
06-11-2009, 11:47 PM
Hello All
We sell those 80lb injectors with both connectors so you don't need any adapters:
http://www.bmotorsports.com/shop/advanced_search_result.php?x=0&y=0&search_in_description=1&keywords=80lb
In your case, to keep your EV1 / MiniTimer harness you could use these:
http://www.bmotorsports.com/shop/product_info.php/products_id/1589
If you are stuck, here are the adapters we offer to go from an EV1 / minitimer harness to EV6 / USCAR injectors:
http://www.bmotorsports.com/shop/advanced_search_result.php?keywords=+EV6+to+EV1&categories_id=&inc_subcat=1&x=40&y=14
