Plug for EGR on LS1 Intake
Old 06-07-2009, 09:10 PM
Mike52's Avatar
Default Plug for EGR on LS1 Intake
What are you using to plug the EGR hole in an LS1 intake? When I bought the intake, it had one of the expandable rubber freeze plug type plugs in it, won't look too cool in the street rod. TIA
Mike
Old 06-07-2009, 09:15 PM
crossroads's Avatar
check the WS6 store.....i have one still in the bag somewhere in my garage
Old 06-07-2009, 09:27 PM
4150's Avatar
GM part number 12558346
$18.43 through Scoggin-Dickey(sdparts.com)
I'm a not a big fan of the rubber freeze plug either
Here it is
Old 06-08-2009, 02:00 AM
5_02ls1's Avatar
that is whats in mine but i have used a regular steel freex plug on other intakes...
Old 06-08-2009, 11:22 AM
NemeSS's Avatar
i use steel or brass freeze plugs.
1 3/8 diameter. work excellent, never leak
just tap in place with large socket and mallet
Old 06-08-2009, 06:26 PM
bdrussell's Avatar
Mike
You bought a LS1 intake? The LS6 intake wouldn't have that pesky hole to plug you know
Never thought about that fact when I bought a LS6 intake and then went... hmmm, how do I keep it CA legal and keep the egr junk...
Old 06-09-2009, 09:43 AM
ramair21's Avatar
what did you do if you dont mind me asking????
Old 06-09-2009, 07:58 PM
Fb0dy0nly's Avatar
On one LS1 intake that needed to be sealed, I took a piece of black UHMW plastic and cut it to fit the top square part and glued a solid washer on the underside that fit the hole perfectly. With the UHMW screwed in tight and the washer in place, I didnt have an issue with leaks and it looked stock.
Old 06-10-2009, 09:42 AM
Mike52's Avatar
A big thanks to all for your replies and suggestions!!
Mike
Old 06-10-2009, 11:40 AM
bdrussell's Avatar
We left the egr tube on the car, but cut it a bit short and plugged it up, changed the codes in the computer to show it was working(since CA checks to computer for codes...), and then made a pipe that has the same design for the egr to bolt down on, fit on the top of the intake and makes it look like a stock LS1 intake for the visual inspection.
Wasn't as hard as it sounds. Took a section of exhaust tube in the right dimension, cut it with the correct radius of the top of the intake, added a tab for the egr to bolt to, epoxied that to the intake.
Old 07-02-2009, 05:46 PM
firstinlastout86's Avatar
any pics??
Quick Reply: Plug for EGR on LS1 Intake
