Removing Headers FROM THE TOP?!?!
Yes it can be done. I had jet hot coated headers and I used a cherry picker to attach to the motor then unbolt the motor mounts to move the motor a little from side to side. Some headers can come right out without unbolting the motor mounts. It will take a little work but it can be done. I perfer to do it that way exspecially if you are taking the heads off. I did mine with them still on.
Putting the SLP's on from the bottom was one of the biggest PITA's of my life. I was hoping that it would be rather easy to slide them out from the top. I was hoping there would be an easier alternative to going through the bottom.
Lemons:
Easier said than done. The car is taken appart. I'd need a tow truck to move it.
Lemons:
Lemons:
Lemons:
