65' Chevy II 5.3 th400 swap
Old 06-08-2009, 11:49 PM
eviltwin_1987's Avatar
Default 65' Chevy II 5.3 th400 swap
My brother bought this car a few months ago and i convinced him to do a ls swap. Car started as a inline 6 and powerglide, it couldnt get out of its own way. the build consists of:
5.3
224/224 cam
918 springs
arp rod bolts
th400 w/ 3500 stall
I will be using a gto oilpan with all stock suspension and steering
you can see the syclone in the back waiting for its new motor
took about 1.5 hours to get to this
next thing is to make motor mounts, figure out what we are going to do for headers and start wiring
Old 06-09-2009, 07:36 AM
TomM's Avatar
Kewl, great progress so far...... You are probably going to have to use shorties, or build a set of tubes. No one is making a set for an LS in a stock clip right now that I am aware of......
Post a lot of pictures......
T,
Old 06-10-2009, 09:50 PM
ces63ss's Avatar
can you take lots of pictures and possible document your built. I have a 63ss and would love to do an LS1 swap without having to change the front clip.
Old 06-11-2009, 12:03 AM
I will try. Motor goes in tomorrow
Old 06-11-2009, 12:48 AM
LQ9CHEVELLE's Avatar
About to begin work on a 63SS nova with a stock front clip also. Going front mount turbo though, using manifolds flipped so exhaust will be different than u. Got Gto pan also. Keep us posted!
Old 06-13-2009, 01:00 AM
from yesterday
made the motor mounts today. will get more pics of everything tomorrow.
Old 06-13-2009, 01:01 PM
today we are going to make the tranny crossmember, pull the motor/tranny, and box and weld the motor mounts. The motor mounts are solid with a poly tranny mount.
Old 06-13-2009, 02:50 PM
Capown's Avatar
thats pimp!! I loved your truck as well!! I lost my motivation to work on my coupe/carbed 5.3 when I got layed off. =( I need to get back on it.
Old 06-13-2009, 09:41 PM
ces63ss's Avatar
SO it does fit. What are you going to do as far as exhaust manifolts? did you have to cut the tunnel for the tranny(4l65 assuming)?
Old 06-13-2009, 11:14 PM
I hear C6 vette manifolds work good on these swaps, when front shock towers are retained. Im gonna pick a set up for the 63 nova im doing
Old 06-13-2009, 11:35 PM
probably going to make LT's for it. Used a th400 and the tranny is against the stock tunnel. i will not be cutting the tunnel. Ill get a pic of how far it hangs down when the motor/tranny go back in
from what i see the c6 manifolds or any other manifold at that would hit the steering box. they dont flow as well as LT's anyway.
made the tranny crossmember and new engine crossmember today. pulled everything out to put the cam and tc in.
engine on the left, tranny on the right
Old 06-14-2009, 05:58 PM
ces63ss's Avatar
did the motor mounts you fabbed up move the motor fwd?
what are your plans for the fuel system?
what are your plans for the electrical side (powering it all up)?
Old 06-15-2009, 12:05 AM
The mounts have the tranny about 1/2" back from stock
We sumped the stock tank, using an inline walbro with stock truck rails for now
I have a cut up truck harness I will be using to make my own harness again.
Old 06-26-2009, 07:12 PM
"update"
haven't made the headers yet but tried some c6 manifolds for the people wondering of they would fit. In no way, shape, or form would they fit without hacking up the strut towers like crazy.
other than that all the car needs is a radiator and wiring harness. been busy with another project but will get back on this in a few days. more pics to come.
Old 06-27-2009, 12:45 PM
MeanYellowZ's Avatar
I think we were separated at birth....awesome projects man...the pic with the Chevy II, Syclone in the background and your truck sitting on the street is killer......
Old 11-24-2009, 03:43 PM
danbap's Avatar
any more pic/updates?
Old 11-24-2009, 09:17 PM
LS1Tech Sponsor
psiconversion's Avatar
Nice fab work. I dont know about you, but putting a th400 is a PITA in a chevy ii.
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Old 11-24-2009, 09:22 PM
car has been done, just tacking some ecm problems. i will get some pics soon.
it took very little massaging with a 3lb hammer
Old 11-24-2009, 09:58 PM
danbap's Avatar
what did you do for headers?
Old 11-24-2009, 10:34 PM
i made some
Quick Reply: 65' Chevy II 5.3 th400 swap
