Suspension & Brakes - Suspension?
PONTIACTRANSAM94
06-09-2009, 05:19 PM
I got i 94 tramsam and i got an eibach pro kit on it and was wondering what size rims are you running. I want to go with a 17 up front and 18 in rear will they fit with out any clearance problems.
SSmoken
06-09-2009, 05:35 PM
Should. I had sportlines with 18's all the way around.
98TAjwh
06-10-2009, 01:23 PM
they will fit, i have 19x8.5 up front and 19x9.5 in rear. in retrospec i wish i would have gone smaller. can't find a drag radial to fit on a 19" rim. that was my one newb mistake....so far
z28bryan
06-10-2009, 03:07 PM
If you stay around 275 width tire or up to 9.5 rim width, then rim diameter shouldn't make a difference. (Assuming you stick with stock tire diameter)
PONTIACTRANSAM94
06-10-2009, 03:15 PM
Well the rear rim is a 10.5 and i was wanting to run like a 305 rear tire
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
