anyone ever use their purge as a 2nd stage dry shot?
Old 11-09-2003, 06:41 PM
single digit dreamer
parish8's Avatar
Default anyone ever use their purge as a 2nd stage dry shot?
i am running a nx wet kit, it came with a purge solenoid but i dont use it, just purge thru the motor, any reason why i couldn't use the purge solenoid for a 1st stage dry shot? just need a line and a jet holder, it would be super easy to set up.
thinking a 100shot dry into the air filter and a 150 or so wet a second or so later.
Old 11-09-2003, 06:47 PM
silverTA's Avatar
i was thinking about doing it
TTT
Old 11-09-2003, 07:53 PM
W8N2SQZ's Avatar
Parish, I know fireball did something like this a long time ago. I would go for it. if you do it, let me know what fitting you buy from NOS to hold the jet and spray into the lid
Thanks,
Glenn
Old 11-09-2003, 11:11 PM
parish8's Avatar
Thanks,
Glenn
my purge solenoid has a -3 fiting off of it, the nx jet holders that go with the shark nozle have a -3 flare fiting also, the jet is the tapered part of the flare. just one of those jet holders along with about a 4-6' -3 line and a nut or tap to hold that jet holder to the airbox would be it for parts, something like $30 total i would think.
also some kind of control, now that i think about it i probably wouldn't use it as a 2 stage but more as an incab adjustable set up. spray it all out of the hole(with window switch and stall) but be able to choose at the flip of a switch weather to run no nitrous, or a 100dry or a 150wet or both the 100+150. or just save the extra shot for if it looks like i am going to loose a race.
Old 11-10-2003, 07:57 PM
B18B1LS1's Avatar
I did this as a quick second stage on my Civic. It's easy, cheap and very effective........
Jeffrey
