Cometic Gasket
Old 06-09-2009, 08:24 PM
driftpin's Avatar
Question Cometic Gasket
I'm ready to install my heads and I'm trying to figure out if I can get away with 93 octane gas using a 3.910 bore .040 thick head gaskets or would I be better off with the .051.
I have a 62cc combustion chamber and a deck volume of -.008.
I'm running TEA stage 2 243's
and a my cam is 226/230 .598”/.600
I'll be shooting a 150 shot of juice into it too so if I can get away with the extra compession I'd like too.
Thanks for any help.
Old 06-09-2009, 09:45 PM
405HP_Z06's Avatar
Here is your SCR calculation. You should have no issues with 93 octane. I'm DD'ing 11.31.
Old 06-10-2009, 07:01 AM
driftpin's Avatar
Thanks Aaron
I have heard others on here saying that a .045 quench is desirable. Is .032 going to be alright for decent combustion?
What program is that? Thanks Aaron
Old 06-10-2009, 12:32 PM
A_VAS's Avatar
the tighter the quench the better resistance to detonation...so yes .032 will help you. That a nice tight number.....
Old 06-10-2009, 01:21 PM
JBIRD02's Avatar
Well, the 1st response pretty much covered it, but fwiw, I have a similar setup as you. 62cc 243 heads, w/ Cometic .045's, and 226/236 110lsa cam. Runs great, and I have no problems at all. Good luck with it!
Old 06-10-2009, 07:27 PM
405HP_Z06's Avatar
Originally Posted by driftpin
Thanks Aaron
The software is Performance Trends Compression Ratio Calculator.
On a steel rod street engine, .032" piston-to-head clearance is about as close as you want to go. As previously stated, the tighter the quench the better. Improved mixture turbulence increases motion, efficiency, and helps to prevent detonation.
