LT1 Belt tensioner replacement
Old 06-09-2009, 11:19 PM
hitmanws6's Avatar
Default LT1 Belt tensioner replacement
How do you replace it and where do you get one?
Old 06-10-2009, 11:26 AM
themadspoon's Avatar
You should be able to get one at and auto parts store. As for replacing it you will need to take the belt off its a 13mm in the middle of the tensioner pulley, and then there are two bolts on the tensioner i believe they are 10mm. It is easiest to do it from below.
Quick Reply: LT1 Belt tensioner replacement
